The steel cable cord stripper is a necessary tool to strip and separate the steel cables of conveyor belts. It can be used as core of various fabrics, plastic canvas rope of steel cord conveyor belt and the decision between the canvases. Introduction Steel cable belt cord stripper is used to strip various steel cable conveyor belts, it is widely used in field of cement plant, power plants, mining, belt company, steelworks and port, etc. Features 1)Max. strip width till 200 mm, speedy and reduce labor intensity and save time; 2)Lightweight, carry easily, simple operation and stable. Technical info 1. Power supply: voltage 220V/380V 50/60HZ 2. Power: 3 KW 3. Weight: 96 KG 4. Applicable Range: 650mm~2200mm width of steel cord belt 5. Altitude: < 2,000 Meters 6. Ambient temperature: -20°C~+40°C 7. Relative temperature: < 85% 8. Dimensions: 590×360×470mm Product range 1. Max. strip width till 200 mm, speedy and reduce labor intensity and save time; 2. Lightweight, carry easily, simple operation and stable.ST Belt Strip Machine website:http://www.arphu-en.com/belt-strip-machine/st-belt-strip-machine/ |
